Decals selecting problem
Hello!
So I made an offset plane, and then placed a decal on that plane. Not only is there a red border around the decal, but I cannot select the decal. And the problem isn't with my filters either. I've been trying and researching for 2 days now and I can't find a way to select the decal.
jeff_strater
Hi @Anonymous,
I assume that you mean an "Attached Canvas", not a "Decal"?  You cannot place a Decal on an offset plane (unless there is some bug there).  If you can share the model and a screencast, we will take a look at it.
thanks,
Jeff
Jeff Strater
Engineering Director
You are correct I used 'Attached Canvas', my apologies. Attached is a screenshot of what the images look like in the model, again with no way to select them. They are not visible in renderings.Attached Canvas images.PNG
jeff_strater
very strange.  If you could possibly export the design as a Fusion Archive (File -> Export) and attach it here, we will take a look.  The first step will be to see if it's reproducible here.  If it is, then we can investigate it as a bug.  If not, then we will need to ask some questions about your setup.
BTW, it is normal that canvases are not rendered.
Jeff
Jeff Strater
