Dec 2016 problem with dimension input with parameters
kevin
kevin
In the November 2016 release I observed a problem with sketch dimension input with parameters. I saw at least two posts in this forum related to this but no real acknowledgement from Autodesk (and December didn't fix it).
I took a few minutes to nail down the problem I am observing to document it in the simplest manner.
See attached screencast.
Kevin
kevin
jeff_strater
Thanks for the video.  Yes, this is a known issue with parameters and focus.  We are working on a solution and hope to release it soon.  Until then, the workaround you describe (hitting return/enter), or picking the parameter from the list, or just clicking into the text entry box to return focus, is the best way to deal with this.
We apologize for the inconvenience.
Jeff
Jeff Strater
Engineering Director
