Debossing to a bell shape
All - Per @TheCADWhisperer 's excellent suggestion on previous topic thread: EMBOSSING TO BELL SHAPE THREAD LINK , I'm restarting this as a separate thread here.
I'm attempting almost the same operation, but also running into a slightly different issue. I wonder if someone can point me to the issue. I have a body for the bell itself and used a conical approximation to split the face with the text I need, but can't get the press pull to work. I'm trying to inset the text in this case (debossing), FWIW.
I'm getting this error when I try:
"Error: An existing fillet or chamfer could not be detected.
Try suppressing or deleting existing fillets/chamfers before attempting the operation."
The wrinkle here is that the text falls directly on a split line in the outer surface of the bell. I'm not sure if that's the issue or not, but I can't get the press pull to work. I suspect something happened at that split line due to variations in the surfaces between the bell and the cone I used to split the bell surface.
File attached if anyone can lend a hand, I'd be VERY appreciative!
Here's the original bell I'm modeling:
Thank you!
Matt
@TheCADWhisperer stated there:
Are you ready (and willing) to start over from scratch?
Step 1 is to Calibrate the image to correct size.
So, to be clear, that diagram provides the profile of the bell, but there are multiple sizes of bell possible and I had attempted to size my design (maybe not correctly?) for a 14.25" diameter bell size. I'm including a table from the same manual which shows various bell parameters. I am loosely going for #9 type on that table, as it's my best guess on the specs for this bell.
I am having to scratch the back side of my brain to recall the actual size (I photographed the bell in 2014, so it's been a minute. I am pretty sure it was more than 10" in diameter, though. I don't think it was 75lbs, but it was fairly heavy.
I am willing to start over if needed. I originally outlined the profile in a separate SVG file and imported those vectors for my starting sketch. I think that's apparent from the history, but just in case it's not. That SVG contained the diagram JPG as well as the traced vectors from Inkscape.
Matt
