Data Red
2 REPLIES 2
276 Views, 2 Replies
Data Red
Good evening
Can you tell me why some data in my list are red?
thanks
Tags (1)
2 REPLIES 2
It's a glitch in the display styles that popped up in the last update. I think it should be getting fixed.
I have found that if you turn on the Environment Dome, it disappears. Also older models from before the last update will show correctly.
Thank you very much Ndenekamp!!!!!!
 I played a bit with the effects and the red is gone!
hopefully they resolve the bug as soon as possible
