CV Spline Implementation Details
bpoweski
bpoweski
I'm in the process of generating CV splines for a model outside of fusion and would like to know some of the details on how they're implemented so that I may unify the calculations.
Effectively, I'm looking for something similar to what is discussed here http://www.theprovingground.org/2012/09/interoperable-geometry-part-1-curves.html.
1.  Does Fusion 360 follow the sample implementation choices as Revit?
2.  How does Fusion 360 choose the knot spacing i.e. are they uniform?
jiang_peng
Thanks for using Fusion360!
  1. Yes we are following the sample of Revit
  2. Yes the knot spacing is uniform.
For example, a degree 3 and 7 control points spline, the knot vector is (0, 0, 0, 0, 0.25, 0.5, 0.75, 1, 1, 1, 1). Please note some operations will manipulate the knot vector, such as Trim/Break/Insert control point/Remove control point. The knot vector is no longer uniform after the operations.
thanks
bpoweski
Thank you!
I’ve been using scipy differential evolution to fit CV splines to sketch points in order to create smooth fair curves.  After a bit of fine tuning it’s working out quite nicely.
Once CV splines are in the API (last I checked they were not) it should make for a useful extension.
