Cutting a Sketch From a Curved Solid
Good Evening All,
I was trying to find the simplest approach to projecting a sketch from a plane to wrap around a hollow cylinder.
I'm trying to make a twist lock type housing. I thought this would be a very simple task but it's turning out to be quite a bit more difficult than I had anticipated.
If I extrude from a plane tangent or offset from the cylinder, the geometry of the extruded cut distorts the shape. I need the geometry of the cuts to flow with the curves of the cylinder.
