cutting a profile from a imported model into design body
matthew_pitmanZJ9ZL
matthew_pitmanZJ9ZL
Hi all very new to design with fusion. i want to cut the profile of the part out in the body ive created so the part nestles in the fixture and the repeated that for a body to fit over the top to clamp the part down for a milling fixture. whats the best way to cut a profile out of the part. ive attached the file.
matthew_pitmanZJ9ZL
file below in replies
kacper.suchomski
Hi
Please use the Combine command in cut mode with the Keep Tool option selected.
Kacper Suchomski
jhackney1972
The one solution proposed is probably possible but cannot be verified because the Fusion file you attached was created using the Fusion Insider Edition.
John Hackney, Retired
