01:53 PM
Sorry if this question is simple, I am very new the 3D modelling.
I'm trying to remove two rows out of this test tube rack.
Since there are connectors at the side, I thought it might be easiest to remove two rows from the centre and then glue the rest back together? Is this possible?
See attached file.
Thanks for any help you can provide in advance! 🙂
Link copied
