Customize Right-Click Context Menu?
kjav
kjav
Is there a way to customize the menu that comes up when you right click?
When I'm doing sketches, I use Project all the time, but I've never ever used the hole tool. When you right click, the menu that comes up, has "hole" in the 5-oclock position. Is there a way to customize the items that come up around the pointer when right clicking?
Thank you.
jhackney1972
No, at this time, the customization of the right click context menu is not possible at this time.  I am sure you already know it is assigned to the "P" key and you can assign it to the "S" shortcuts menu.
John Hackney, Retired
YoavFriedlander
tl;dr version - I believe you simply can't 😞
I believe you can only change shortcuts from menu items but not from the context menu. I also believe there is no way to bypass such situation through the API as I believe not supporting hot keys (Keyboard Shortcuts).
Here is a link to a tutorial that clarifies how regular shortcuts are made or modified - although I suspect you already explored that option given your question. https://www.youtube.com/watch?v=gSgK5vEQJAw
