Custom title block
Custom title block
Custom title block
If a custom title block has been inserted things like sheet numbers have to be updated manually, is that correct please?
HughesTooling
According to this page auto populate is being worked on. http://www.autodesk.com/products/fusion-360/blog/2d-drawings-check-roadmap/
Mark
Mark Hughes
Owner, Hughes Tooling
Thanks Mark,
I wish they would update the one that comes with Fusion 360, that would be good enough for me and probably most other users too.
cmiller66
Hi Cx2,
As Mark mentioned above auto-population is definitely on the roadmap and working its way up the "To Do" list.  Especially once we get multi-sheet out, we don't want users to have to re-enter all of this data on each sheet.
Just wondering, besides the fields we currently do pre-populate (Project name, Title, drawn by, date) which others would you most like to have?
Chris
Hi Chris,
I would be more than happy if the current one was tweaked slightly.
This one is too high, especially for A4, I would like to see the length extended and the height reduced.
Dept, Technical reference, Document type and Document status all removed.
1st or 3rd angle symbol automatically added depending on format.
General dimension/surface finish tolerance field.
Material field.
Customer reference #.
Place for company name or logo.
Break sharp edges should be standard on all templates.
If the current one was adjusted I think many users would have no need to import any others.
HughesTooling
Chris
For a single part drawing I'd like access to folder name, component name, body name, material, weight and scale. You can get the component name and material with a BOM at the moment but for one part in a drawing that doesn't really work.
Thanks Mark
Mark Hughes
