Custom Template For assembly with subassemblies.
Ex_Machina_Engineering
Hello everyone,
My question is, can we create a custom drawing template that will also put the component detail sheets after a subassembly or must I do that manually and the splice drawings together?
jhackney1972
This blog article and video show you probably the only workflow available to achieve what I think you desire.
John Hackney, Retired
Thanks for the link. I went through the article and video but it is not what I'm looking for.
I've set up a template that automatically creates sheets for the assembly and each component separately, including folded and flat pattern sheets for sheet metal parts. I did that with the "smart template" functionality built into Fusion.
The problem is that when a top-level assembly has subassemblies and it gets to one of them, I only get the assembly sheet (isometric view, BoM table, etc.). It then moves on to the next part without "analyzing" that subassembly to its components.
I wanted to ask the community if there is a way around it or if this is the current state of the art, as it were.
