Custom Materials - Brick
beau.turner
Message 1 of 9
beau.turner
Is there a method to support custom materials? Specifically I need a brick (red) to show the design in context to installation and can find very little to no masonry (there is a CMU). Suggestions or a request. 🙂
Replies (8)
Message 2 of 9
herzinj
Hi Beau,
Check out the Screencast below.  What I did was grabbed a .jpg file of a red brick, applied a material in the rendering environment (carbon fiber), and then in the advanced parameters for the material I changed the image from what it was to the brick .jpg file that I downloaded.  If you play around with some of the other parameters (and depending on the image) you will get different results!  Hope this helps!  (http://autode.sk/1CiAbPQ)
James
https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png
Message 3 of 9
beau.turner
Thanks, that did the trick. Was not intuitive at first and had a weird rotation issue but easily fixed with just a few minutes review. Appreciate the pointer!
Message 4 of 9
beau.turner
James,
How would you individually control the rotation of the texture map? Specifically after assigning to the faces in the image I have these results (trying to do this as one texture and not two +). Rotation.png
Message 5 of 9
beau.turner
Here are my settings used (note the weird rotation that Fusion seems to have ie 90 degree rotation in the Texture Editor).
Message 6 of 9
herzinj
Hey Beau,
If I understand correctly, you want to control the direction of your image per face, right?  That way the bricks look like they are laid in real life, or at least generally like that.  If I was a betting man (and I am) I would say that is not currently possible.  Since these values are applied to the body, they will remain consistent.  That being said, you can easily right click on the material that you just created and choose to duplicate it.  If you go back in and modify the rotation again so that it is now lined up the way you want, you can then apply the new material to the face of interest and get the look you want.  I know it is a few extra clicks, but I'm guessing this is the best/fastest way to go about doing this at the moment.  I'll bounce this off of some others to see what they have to say.
Let me know if you have any questions!
James
Message 7 of 9
beau.turner
Thanks James, that's what I was afraid of. 🙂 Also check out that odd rotation in the texture editor vs. the way the image is when you view it (ie has a rotation that should not be applied to it).
Message 8 of 9
hutchij
Agreed, that you can accomplish what you want by using box mapping and duplicating materials to independently control the texture rotation. This is a bit cumbersome now, but we are actively working on improvements.
Here's a wood block with boxmapping and separate face materials for face grain, edge grain and end grain.  (Model courtesy of CB)
Message 9 of 9
Hey James
I am trying to follow you screencast to apply custom image as texture to my model and I don't see drop down menu "image" anymore next to "color".
Was feature removed in latest update?
But "texture map control" is still there...
Am I missing something?
-dan
