Message 1 of 9
Hello ,
I am using a Custom Environment for a rendering . But I have one problem , When I use a Custom Environment and select the flatten Ground , the Environment gets stretched at bottom ground ends. See the 1st image . I need a Ground plane and also a Flatten ground as the model is a Car . What can I do . If I do not select the flatten ground , see the image 2 what result I get . I want my car to be on ground so I can see the shadows and details , It will help to look more realistic . This issue occurs with every Custom environment attached . Please help me Out . or give me some ideas .
Thanks in Advance .,Second
Sanket Patil
Mechanical Engineering
Expert Elite
Expert Elite
