Custom Appearances
Custom Appearances
alan
Custom Appearances
alan
I would like to make or find more appearance files.  The best would be to find a suitable file to download.  I also want to be able to keep the file in my appearance library.  The appearance I am needing is an "abrasive appearance". Can anyone help?
Thank You!
jhackney1972
During the development of this reply and Screencast on how to create a Fusion 360 Appearance, I created an appearance library of one appearance that I have zipped up and attached.  Creating a new appearance is easy, it is just getting a good artwork sample to work with.  I use Techsmith Snagit as my capture and editing tool but Windows 10 Snip-it will probably work very well.  Take a look at the Screencast to see how it is done.  The one thing to play with is the size of the image declared in Fusion 360 that it will tile to cover your surface, you will see this in the video.  I also show you how to load the attached library at the end of the video.
John Hackney, Retired
alan
Excellent thank you!  That should work wonderfully.
