Custom 29MM Thread Size
narey3AVQN
narey3AVQN
Community Visitor
Community Visitor
Hi guys,
I've commissioned a project, and one of the fittings needs a 29MM thread - the engineer uses Fusion360 and said that he does not have a 29MM thread size available and that it would need to be made, then imported into his software to use it.
The above picture is what he needs to select to complete the project, does anyone know if anyone sells thread profiles for what I need, or if I can commission anyone to make the above spec?
Thanks!
HughesTooling
Take a look through this thread where there's a utility to help create custom thread XML files for Fusion.
Mark Hughes
Owner, Hughes Tooling
narey3AVQN
Community Visitor
Community Visitor
Thanks for linking this.
I've already sent him this previously, but he isn't willing to spend the extra time to make it, or alter an existing CSV to fit - so I'm hoping I can commission someone to do it on his behalf just to get this project finally over the line 😕
andrew2085
These values are 1mm smaller than the M30x3.5 6g spec used by Fusion:
  <ThreadSize>
    <Size>29.0</Size>
    <Designation>
      <ThreadDesignation>M29x3.5</ThreadDesignation>
      <CTD>M29x3.5</CTD>
      <Pitch>3.5</Pitch>
      <Thread>
        <Gender>external</Gender>
        <Class>6g</Class>
        <MajorDia>28.7345</MajorDia>
        <PitchDia>26.568</PitchDia>
        <MinorDia>24.732</MinorDia>
      </Thread>
    </Designation>
  </ThreadSize>
Warmingup1953
Using Andrew2085's code, I asked Autodesk Assistant to help. "It" added the spec in the right location then prompted a restart as the Cache would not clear, and then I simply used the Thread command that now has M29 added.
WARNING: I have not tested
Drewpan
What is the actual requirement for this custom thread? Under normal circumstances
a Designer would simply go to the next standard thread size, 30mm in this case. A 1mm
increase in thread size shouldn't cause significant issues unless there are incredibly
tight clearances. Has the Engineer actually calculated the physics of using such a
specific thread size and come up with this for actual clamping and vibration reasons?
How many of these custom size fasteners are required? If you need a handful then it
will be much cheaper to simply use an alternate. If you need Hundreds or Thousands
it will be significantly cheaper to redesign for a larger size.
The fact that you "can" make custom thread sizes in fusion doesn't mean you "should"
do so. Standards exist for a reason. Sure a 29mm fastener is a significant size but it
will still involve custom fabrication and that costs money and time. The other problem
you may run into is - do you also need a custom tool to use it? There will be no 29mm
spanners or sockets and it may not be suitable for some kind of adjustable tool. What
about future maintenance in the field? A custom size fastener could cause all sorts of
issues, especially in a remote location.
I am asking these questions for my own curiosity but also because any engineer should
be asking these questions when creating designs.
Cheers
Andrew
pkomatlapalli
Hi @narey3AVQN ,
Good day!
We would like to check back on this issue. You have received responses for your post from these community members andrew2085 and Warmingup1953. Does any of these responses helped resolved your issue.
If yes, please click on the "Accepted Solution" button, It would be very helpful for others who may encounter the same issue in the future.
Thank you!
Pavan Kumar | Community Manager
