Curved Staircase
Curved Staircase
brandonbattle11
Message 1 of 18
Curved Staircase
brandonbattle11
I am trying to learn how to design a curved staircase. I have the inner diameter, the other diameter, the overall height, overall run of staircase (measured on the curve), the total number of treads, the rise per tread, and the run per tread (based on inner diameter). The inner diameter is 210" and the outer diameter is 273". The total rise of the staircase is 133.75". The overall run of the staircase on the inner diameter curve is 147.75". I have 17 treads. The rise per tread is 7.54" (I'm sure 7.5" will work). I'm not 100% sure where to even start. I've drawn my two circles and messed around with the coil function as well. If anybody can help me learn the correct process, that would be great. Thanks in advance.
Replies (17)
Message 2 of 18
kacper.suchomski
Hi
Create a model of one stair step and a central pipe, then attach your design in another answer.
Kacper Suchomski
Message 3 of 18
brandonbattle11
I will get started on this. Just to clarify, this is a curved staircase and not a spiral staircase. Not sure if there is a difference in design between the two, but just wanted to clarify.
Message 4 of 18
kacper.suchomski
We're still waiting for your step model.
It's also a good idea to include a handwritten sketch of your desired outcome on paper.
Kacper Suchomski
Message 5 of 18
brandonbattle11
Here is what I have now. Also, a picture of my information I have for the project.
Message 6 of 18
kacper.suchomski
Thank you, but I'm waiting for a model of one step.
One specific step has a certain form and geometry.
Kacper Suchomski
Message 7 of 18
brandonbattle11
Is this what you're looking for? Or closer?
Message 8 of 18
brandonbattle11
I am now stuck here, if I am even on the right path. I need that 12" tall coil section to rotate and be on the inside of the stairs.
Message 9 of 18
TheCADWhisperer
@brandonbattle11
Assembly Constraints (or Joints).
Message 10 of 18
Warmingup1953
Is this what you mean by run?
EDIT: Sorry the Forum posting is all at sea!
Edit 2: Construction method? Materials?
Message 11 of 18
brandonbattle11
I am finally back to work on this project. If you dont mind me asking, can you clarify the steps you took to get that 12" flatbar attached to the stairs? This is an updated version of my project about as far as I can get. I need the steel and the wood to combine and not sure how to do that.
Message 12 of 18
kacper.suchomski
Look at this:
Kacper Suchomski
Message 13 of 18
brandonbattle11
That was awesome. Thank you for showing me new methods of assembly that I did not know. I will retrace my steps and practice this method. I have another question that I'm sure theres a simple answer to. I have figured out my flatbar and tread assembly, now I am trying to assemble angle iron on the bottom of the treads. I have one piece drawn in, perfectly centered on the tread and tangent to the curve of the steel. I tried to do pattern along path and cannot get the angle iron parts to spread evenly on my assembly. They need to be centered on each wood tread. I tried "spacing" and "extent". Got any advice? Attached is my latest model.
Message 14 of 18
kacper.suchomski
Two tools are used to define relationships between components: constraints (shown in the previous videos) and joints.
They should be used interchangeably, depending on the circumstances.
Kacper Suchomski
Message 15 of 18
brandonbattle11
Thank you. I'm wondering if there is a way to pattern that angle iron onto all of my treads or will I have to draw each angle iron piece in one by one?
Message 16 of 18
kacper.suchomski
No, you should insert subsequent instances of the same components into the project.
You should proceed similarly with the steps.
If the steps are identical, you should create a single model, insert it multiple times, and position it relative to the previous one using constraints.
Kacper Suchomski
Message 17 of 18
brandonbattle11
Awesome. Thank you so much for the help. Love learning new things about fusion. Thanks for making that do-able.
Message 18 of 18
lauri_barnhart
Hello, @brandonbattle11,
Just checking in—did the responses shared by @kacper.suchomski, @TheCADWhisperer or @Warmingup1953 help clarify your question?
If so, please consider clicking the "Accept Solution" button. Doing so helps others in the community easily find useful answers.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
All the best,
Lauri | Community Manager
