Curve smoothing & merging / concatenate segmented curves for surface creation
In some CAD systems, I have found it useful to concatenate specific curves, then interpolate/smooth them out with a given deviation. This helps e.g. in rebuilding areas with larger, smoother surfaces instead of dealing with too many small segments.
Is there an efficient workaround in Fusion 360 to achieve this? Or could a feature like this be considered for future implementation?
A related topic: Sometimes, surface boundaries are created from segmented curves (e.g. after merging two surfaces together). Even if these segments maintain curvature continuity, the resulting surface still inherits those divisions, rather than forming a single smooth surface. Is there a way to replace such segmented boundary curves with a single unified curve (either identical or smoothed out if necessary) before generating the surface? And I don't mean fit point spline approach because it does not really guarantee deviation limits (without potentially multiple reiteration loops) which can result in a surface which cannot be sewn together with the adjacent one.
This actually has use for many applications in Fusion (sweep/loft guide/rails/path) when there is an error "curve not continuous in tangency/curvature"
I think it would be a fantastic improvement in already great Fusion functionality.
Thanks for any insights!
Best regards,
Lubos
