Cube view orientation clocked from part orientation
matthew
matthew
I was wondering if the origin can be rotated according to the orientation cube in the upper right corner of the Fusion window?  If you take a look at the screen shot I have sent, you will notice the green line (Y positive) points in the Y positive direction only when the orientation cube is clocked -90 degrees.  I believe this is causing rotational issues in the 3+2 machining.
HughesTooling
Hi Matthew
Take a look at this thread.
http://forums.autodesk.com/t5/general-fusion-360-questions/layout-orientation/td-p/5438998
Mark
Mark Hughes
Owner, Hughes Tooling
