Creating sketch 'outline' from face
Dylan.evansEJABQ
Message 1 of 8
Dylan.evansEJABQ
Hey,
So bare with me if I'm asking an odd/noob question, I'm still very new to modelling in general but especially solid modelling in F360.
Below is an image of what I have, which is a face cut out of a curved solid.
What I would like is for the outline of this face to be a sketch that I can loft to (I know I can loft to the plane, but thought a sketch would be easier to work with. Correct me if I'm wrong)
So is it possible to just keep the outline of the shape and get rid of the face which I don't need?
Screen%20Shot%202017-02-08%20at%2017.05.08
Replies (7)
Message 2 of 8
Beyondforce
Please attach the file and I'll show you how to do that.
Ben.
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 3 of 8
Dylan.evansEJABQ
Hi Ben,
Thank you very much, here is the file.
Message 4 of 8
Beyondforce
Here you go, if you need more please let me know:
Ben Korez
| YouTube
Message 5 of 8
Dylan.evansEJABQ
Dead easy when you know how!
Thank you very much!
Message 6 of 8
Dylan.evansEJABQ
When this sketch is created the line/s it creates dont seem to be joined.
They dont select as a chain if I want to choose them to loft to for example, and if each line is selected using cmd/ctrl then loft is selected afterwards it creates several profiles and bugs out.
Is there any way to fix this, I read topic which seemed to be for a similar issue and it didn't seem a proper 'join' command had been implemented yet?
Message 7 of 8
davebYYPCU
Depends if it works for you, how big the gaps may be
Try to break the links, and then make endpoints coincident.
Message 8 of 8
Beyondforce
By default the "Chain" checkbox is not selected. Just check the "Chain" check box and it will select all the line.
Ben.
Ben Korez
| YouTube
