- Mute
- Permalink
- Report
Ok here is my situation, I create a body, I shape it a bit and then make it hollow say on the lower inner corner, now I want to create structures in a specific path from the lower solid section to the upper section of the new gap created. I can click on or create points which would be ideal if there was a "Create line from points" functionality but that does not seem to be the case, every time I try to create a line to thicken after defining two points I have to pick a plain to draw on and I am completely unable to accomplish getting a line between two points, pre selected or otherwise.
Is there a functionality to basically click on two point/verities and then create a line between them to facilitate creating a face to thicken?
