Creating an internal lip inside a parametric 3-way (XYZ) pipe fitting?
trevormead
trevormead
I'm creating a network of pipes attached with custom fittings at each intersection. Goal is to have a model of connected pipes and fittings mapped to a 3D sketch, so I can adjust the sketch lines and angles and the pipes and fittings will adjust accordingly.
For various reasons I'm starting with the fittings first (neither extruding pipes from the 3D line drawing nor creating stock pieces of pipe and editing them were working well). In the attached file, I got a basic connector working the way I want: it's 3D, and the angles of the pipe connectors adjust after editing the angle of the sketch ("Outer fitting"). Now I want to add a lip inside the fitting that stops the pipe from going in too deep. I tried sketching and extruding a second fitting ("Inner fitting") and joining the two bodies, but they still move independently. Also tried projecting the Inner sketch onto the Outer sketch so I could constrain the overlapping angles, but it seems Fusion only allows Driven dimensions between projected lines which can't be constrained to match other dimensions. What I haven't tried is sketching a more traditional 2D version of the connector that includes the lip and using Revolve, because I can't wrap my head around how to translate that process to an XYZ configuration.
Very new to Fusion so I'm sure there's plenty to say about my workflow and terminology, but given the short-term goal of creating a lip inside the adjustable fitting, 1) is there an easier way to go about it, or 2) am I generally on the right track, just doing something wrong?
Edit: removed file to reduce confusion, see below.
davebYYPCU
... and the angles of the pipe connectors adjust after editing the angle of the sketch ("Outer fitting").
Not working here, I changed the only angle in the first 2 sketches to 110 and broke the file.
You description is confusing.  Will the corner piece remain fixed on the origin planes, or would be other angles?
Might help...
trevormead
Broke for me as well upon reload, let me try again from a clean slate.
I have this. The sketch is simple.
Changing the angles of the sketch changes the piece from a fixed origin as desired.
I want a lip inside of each socket which would look like this:
How do I build that lip in each socket and preserve the ability to adjust each angle as described above? New file attached.
trevormead
Update: I was completely overthinking it. Just made the holes on the piece slightly smaller than needed, then used a cutting pipe to bore out the socket ends, leaving a small section inside as the lip. Duh.
