Creating a tapered radius
I need to create a tapered radius on the bottom corner "rail" running from the bow "full rad" and tapering to nothing about 2 thirds along the hull length . Is this possible in "Sculpt". ?
TrippyLighting
Yes, but you can also do that possibly easier in solid modeling mode, assuming your sculpt has a bottom face. Kinda hard to see in the screenshot 😉
That's the beauty of Fusion. You are not limited to having to do anything to a model in Sculpt just because that's how you started the model.
To do this in solid modeling mode, after selecting the fillet tool you can select between three differnt modi, of which one of them is variable radious. Not sure you can go down to zero, just make it small enough to not matter.
dghylin
Another great tip...and you can go to 0 on one end....thanks...
