Creating a Sheetmetal Flange Error
I am making a complex hopper. I would really like the flange tool to allow me to set the angles of the sides. Since I can't I have had to cut the sheet metal to shape with extrusions. I have a part that will create a flat pattern but one side will not allow me to create a flange. This is a spot welded flange.
The error I am getting is "Can't complete Sheet Metal operation due to an internal error. Check the body and bend parameters, then try again." I have tried offsetting the ends away from the other surfaces and only bending 45 degrees so the body does not interfere.
Does anyone know a work around?
