Creating a revolve then modifying to follow spline
Vanguy
Message 1 of 10
Vanguy
Hello!
I want to create this shape with a revolve  in the form space and then bend the centerline to follow that spline sticking off. I have tried doing it with a Loft, but this does not look correct due to the spline shape forming the outside boundary.
Replies (9)
Message 2 of 10
hamid.sh.
I'm not saying this is the best workflow and am keen to here what other users suggest, but your own idea of modifying a From Revolve kinda works if you spend time editing T-Splines (I didn't spend much):
Hamid
Message 3 of 10
g-andresen
try loft with centerline spline
Screencast
günther
Message 4 of 10
TheCADWhisperer
@Vanguy wrote:
I have tried doing it with a Loft, but this does not look correct…
Attach your failed attempt here (the actual *.f3d file).
This will give the Experts here some better clues about your true Design Intent.
Message 5 of 10
Vanguy
Hamid,
Did you get those just by twisting and moving each individual section? I was wondering if there was a way to lay get the computer to put the centerline onto the spline.
Message 6 of 10
Vanguy
Hi Gunther, I tried making a loft before but with the lower feature, a fillet does not blend it correctly.
Message 7 of 10
Vanguy
Here are my first 3 versions and a picture of the 4th.  As you can see in the picture, it looks totally different to bend a form than to loft and then fillet. I did this manually, but what I want is for the centerline of the top to be attached to the spine instead of me putting a bunch of points on there and manually putting them near the centerline.
Message 8 of 10
Vanguy
Here is the loft and fillet version
Message 9 of 10
g-andresen
Maybe a sloping loft base will help?
günther
Message 10 of 10
TrippyLighting
@Vanguy wrote:
...but what I want is for the centerline of the top to be attached to the spine instead of me putting a bunch of points on there and manually putting them near the centerline.
Why ? What is the difference between moving a spline fit point and moving a couple of vertices in a t-spline?
The effect is the same.
