Thanks to everyone for the comments. After experimenting with suggestions, here is where I stand now:
In Fusion on my Mac, I sketched a cylinder and am now trying to place a point precisely on its outer surface so that I can extrude a hole. The point should be at X: 0 Y: 0.875 Z: 0 in.
Using Create > Sketch, select plane, Create > Point, I sketched a point at the approximate desired position.
I then activated the Dimension tool using the D keyboard shortcut, clicked on the point to select it, then shift-clicked on the origin point. This made the Y dimension visible, which I was able to change to 0.875 in.
But I still need to change the X dimension from -0.005 in to 0 in. I tried to do this by activating the Dimension tool again, selecting the point, shift-selecting the origin point, and then carefully moving the cursor back and forth until the X rather than Y dimension was displayed. I clicked on the 0.005 value shown, entered 0 and return. Now an error appears, "Over-constrained sketch."
Attached are a screenshot showing the error, and a copy of my .f3d file.
Suggestions welcome. Thanks in advance.
