Creating a face with help of profiles, rails using project intersect.
I created profiles and rails.
the rails are created with help of project intersect : a blue square appears.
after creating a face with loft which didn't gave the expexted result I checked some of the coincidence point which I created as described above I saw that these point weren't connected .
what am I doing wrong, what is it that I miss.
TheCADWhisperer
I found your screencast on surfacing a boat hull.
That was helpfull.
So first thing to do for me is to execute your instructions for constraining the frame sketches.
thanks so far.
Pieter
Today I did a lot of struggling to define and constrain the FRAMELINE sketches.
Then I created lofts. On the aftship you will notice that creating a loft want work.
In an earlier session I made WATERLINE sketches to be used as rails.
I myself think it is still necessary to make use of rails. therefore I must create them again.
Today I did an attempt to make a waterline sketch with help of project intersect  creating some days ago a waterline sketch everything worked OK ( red dot )
However now with constraint sketches I don't get a dot but a line and that is not what I want.
I hope hope you can give me some advice.
regards,
Pieter
attached:     *.f3d
