Creating a curved text
natleow
Observer Observer
natleow
Observer
Observer
Hi all,
I've been trying to figure out how to curve a text but to no avail, seeking help here please. Below is the prototype of the item that I am trying to replicate:
WhatsApp Image 2024-09-06 at 5.43.24 PM.jpegWhatsApp Image 2024-09-06 at 5.43.40 PM.jpeg
I have the font/2D sketch of the alphabet A, but I am struggling to figure out how to curve it from the top to the bottom of the alphabet, such that the middle part protrudes up. The curved text tutorials that I have found so far are mostly related to curving on a cylinder which isn't what I really want because the bottom of the text isn't flat but curved instead.
I am trying to do this for all alphabets & numbers as well, but need a guide on how to go about doing this please.
Thank you so much and much appreciated!
davebYYPCU
Like this?
Might help....
Drewpan
The way I would do this is to type out your alphabet in a large font along a line.
Extrude the font to say double what you want in thickness.
Create a sketch perpendicular to the text.
Project the text onto the sketch
Create an arc the size you want on the sketch.
Split the Text body with the Arc as a cutting tool.
Remove the bits you don't want.
Lovely curved text.
You should be able to create the letters once. Save each letter as a component and then import and scale them
as needed in your designs.
Cheers
Andrew
