Create trapizroidal thread using fusion 360
Message 1 of 10
I am trying to create a metric trspizoidal thread but the result was a normal metric thread i don,t know why???
Replies (9)
Message 2 of 10
HughesTooling
It was reported quite a while ago the metric trapezoidal threads use the wrong angle,
Here's the header from the thread XML file and you can see it's set to 60° not 30°
If you need a modeled thread you could edit the file and change to 30° but you'll need to update it after any Fusion updates, it located here on a PC.
C:\Users\UserName\AppData\Local\Autodesk\webdeploy\production\1c8eda3d042f236f121d6fb4e850f0621b6f700b\Fusion\Server\Fusion\Configuration\ThreadData
Replace username with your user name and for the number in red you'll need to find the newest directory in the production directory.
Mark
Edit, it's not that easy I just tried and get this. I followed the instructions here and added thread type 0 and 30° angle. I guess the thread data is just wrong.
Mark Hughes
Owner, Hughes Tooling
Message 3 of 10
HughesTooling
@jeff_strater Has this bug been logged, it has come up before here.
https://forums.autodesk.com/t5/design-validate-document/iso-metric-trapezoidal-threads-fusion-models...
Mark
Mark Hughes
Message 4 of 10
jeff_strater
I can't find it, so it probably had not been filed.  Just took care of that.  Thanks for the reminder.  Filed internally as FUS-29976
Jeff
Jeff Strater
Engineering Director
Message 5 of 10
Beyondforce
@HughesTooling,
You are right! someone needs to go through all those XML file and make sure the Data is correct. I have also tried to change the 60 to 30, but something is still not right!
Cheers / Ben.
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 6 of 10
Hi Jeff
I just tried creating a Metric Trapezodial thread, and the issue is still there... mind you more than a year later ;(
Could you pls. follow up on this so we can get it corrected? The trapezodial threading is of course completely useless when the angle is 60deg instead of 30deg.
Best regards,
Martin Skovsø Nielsen
Message 7 of 10
jeff_strater
@Anonymous, unfortunately, no, this bug has not yet been fixed.  I don't have any timeline for a fix, sorry to report...
Jeff Strater
Message 8 of 10
domi259
Is there any new info about this topic?
Message 9 of 10
I've come across this same problem again when trying to model StubAcme threads. Its frustrating, especially after building the XML files for several SA threads in multiple pitches from 3/4" - 2"...
Message 10 of 10
domi259
It always takes a lot of time to do custom threads and I can't imagine that it would be difficult to fix it, so I don't really understand why this topic seems to be unnoticed by the developers.
