Create slider joints on two parallel shafts
SGoldthwaite
SGoldthwaite
I'm trying to create a slider joint on the Z-axis of a desktop CNC model I iimported from Solidworks.  There are two parallel shafts and a lead screw for the z-axis.  When I make a slider joint on one of the shafts, the z-axis head rotates a bit, but that kind of makes sense since I haven't constrained it to the 2nd shaft yet.  But when I try to add a slider joint to the second axis it fails.   What's the best way to do this?
schneik-adsk
Sliders only have one open degree of freedom, a slide along the shaft.
Change the constraint to cylindrical, so that is can slide AND rotate.
Cylindrical joints have two open degrees of freedom, translation and rotation.
Kevin Schneider
SGoldthwaite
Thanks.  I made the two joints cylindrical and now it works.
