Create sketch question
Message 1 of 12
Can anyone tell me why my create screen looks so different then the one in the training video? The plains are not pointing in the correct direction, they used too!
have I somehow changed some setting? how do I get it back to the default and have it open that way each time I want to create sketch?
I’m only going to be drawing to cut sheet metal.
Mine is the second pic. Thanks, Becky
Replies (11)
Message 2 of 12
HughesTooling
Looks like you have Z up but Fusion's default is Y up. Most people seem to change to Z up.
Edit. Changing this setting only changes the orientation for new design, it does not change existing ones.
Mark Hughes
Owner, Hughes Tooling
Message 3 of 12
Thank you. I did change it  like you showed but nothing changed.
Message 4 of 12
TheCADWhisperer
Restart Fusion.
Attach new screenshot images here (including image of your Preferences) as shown by @HughesTooling .
Message 5 of 12
I restarted fusion and it worked. Will it stay that way from now on?
Message 6 of 12
Give me a second and I will add them
Message 7 of 12
Message 8 of 12
TheCADWhisperer
Well, if you got it working there is no need for additional screen shots.
Message 9 of 12
Will it stay as the default now? Thanks, becky
Message 10 of 12
I’m not able to do anything  now, it seams to be froze. If I click on anything I just hear a beep.
Message 11 of 12
TheCADWhisperer
The obvious question - if you restart the computer does Fusion still not work?
Message 12 of 12
i just seen this i have it going now thanks.
