Create scetch allways starts with orbiting the model...
When I design a furniture. Often I have to make some holes, sketch some new things on or in an existing set of details, housings.
So it really doesn't help when I find the view, where I see all the involved parts and details, am ready to start the sketch and as I choose the sketch mode - it orbits away from the view I've found, because, I do need to find the view anyway, to select the face on which to sketch, and in most of the times - it is easier to continue in the 3d view, not the exact face, in front of which there are other objects usually...
Of course - there is the isolation option, but it doesn't work when I need the "Project include" operations to be involved …
… Is there an option to switch on or off to get off this annoying orbiting every time?
HughesTooling
Have you tried unchecking Auto look at sketch
Mark Hughes
Owner, Hughes Tooling
Thank You! - It solved the problem - it is a lot better now!
