Create frame model from object
r.voigtlaender
r.voigtlaender
I would like to create a "frame model" from an object. The purpose is to have something I can 3D Print to test a models dimentions without wasting too much plastic if it doesn't fit. So something like only taking the lines and thicken them od creating a Voronoi on all faces.
I tried the Voronoi plugin but wasn't able to create an object with just less solid faces.
Any ideas or options I can try?
mike.tessier
Hi @r.voigtlaender,
Thanks for posting!
Forgive me, but I am having a hard time visualizing what you are trying to create. Could you post a visual aid depicting what you would like to accomplish?
Mike Tessier
Product Support Specialist
My Screencasts | Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
mike.tessier
Hi @r.voigtlaender,
Have you found a solution to your problem? I am happy to help if you still require assistance!
Cheers,
Mike Tessier
PhilProcarioJr
@mike.tessier
They want something like this:
Video
Fusion can't do that.
Phil Procario Jr.
Owner, Laser & CNC Creations
r.voigtlaender
i found a solution via Meshmixer.
http://www.protobuilds.com/#!How-to-Make-Voronoi-Patterns-with-Autodesk%C2%AE-Meshmixer/c1r1n/554239...
But it is quite random in the resultat. So any better solution is welcome.
Robert
mike.tessier
Hi Robert,
I am sorry that you haven't been able to find a better solution 😞
However, I think I may have come up with a few potential workarounds.
Firstly, you could try shelling your model and putting the holes in manually. Secondly, you could tweak your printer settings to use less plastic. Thirdly, I note that 123D Make has great functionality for making prototypes quickly using cardboard cutouts that you assemble.
If what you are looking for is something more like what @PhilProcarioJr shared, you could try out Autodesk Inventor's Shape Generator or Autodesk Within.
Hope this helps!
Cheers,
Mike Tessier
r.voigtlaender
Hi Mike,
thanks for sharing the extra options. I'll have a look at them.
Robert
