Create flat cut pattern from loft surface
- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Melden
I am trying to flatten/unwrap a curved surface which was created with a loft, and then combined (cut) with another shape.
Basically this is a fairing on a model airplane. It joins the engine cowling to the wing, and it will be made out of balsa wood. I would usually make something like this using a supporting structure, and then "planking" strips of balsa on top, but I recently found online this picture and I am trying to find a reasonable way to do something similar..
I have searched the forums and tried to use mesh mixer, I managed to get a flat surface but, unless I'm missing something, there is no option to set a number of cuts that will make this work before unwrapping. I thought about cutting the initial shape in thin slices before exporting and unwrapping, and then import back in fusion or another software and join them back together, but it becomes so much work that is not worth the effort (as there are several other surfaces to cover in the same way), and I'm not even sure it would work as meshmixer will distort the slices a little anyway.
I attached the surface if it is of any help.
Thanks at least for reading all this!
Carlo
