Create cylinder with two different circle (top/bottom) sizes
eric.schroeder6YQGN
Observer Observer
Message 1 of 8
eric.schroeder6YQGN
Observer
Observer
I created a cylinder with fusion 360. Now i want the bottom of the cylender with a width of 28.00 mm and the top a with of 30.00 mm. How can i do this?
See picture below. The last one shows the cylinder from the side, so you can get a better understanding what i want to achive.
Replies (7)
Message 2 of 8
davebYYPCU
Put a centre line into that line drawing, as a fusion sketch, and Revolve one side of the sketch.
or you can do the maths, and extrude a circle with taper angle
or you can draw 2 circles, at the right spacing and Loft them together
or you can modify  > Draft, but again you need the Maths.
By now you should have an idea that Cylinder command is fairly useless, in a sketch based modelling system.
Might help.....
Message 3 of 8
g-andresen
1. Sketch 1 > Circle 30 mm
2. Construction > offset plane > distance = height
3. Sketch 2 on plane > circle 22 mm
4. Create > Loft > profile 1 > profile 2
5. Modify > shell > Body (loft)  > wall thickness
günther
Message 4 of 8
jhackney1972
As you can see there are many ways to create models in Fusion 360.  You asked for a "cylinder" and you show a cup.  I will demonstrate using a Surface Loft to create you taper cylinder.  You did not specify the height or the wall thickness but you can edit those to suit from the timeline.  Model is attached.
John Hackney, Retired
Message 5 of 8
TheCADWhisperer
You should always Attach the *.f3d file of your attempt here.  (See Attached for the correct way to model.)
Message 6 of 8
snowmanbend
John I followed your directions and it worked perfectly for what I was doing....up to the thickening section. When it indicates select a surface, I have tried every which way to select the cone, and nothing happens. I followed the basic example you put up.
Suggestions?
Tom Combs.
Message 7 of 8
davebYYPCU
Sounds like you used the Blue (solid) Loft tool, (solid bar?)
For surface modelling you have to change to Orange Icon Loft (hollow tube?)
Might help...
Message 8 of 8
snowmanbend
John thanks for help. As a true beginner I was stumped with your comment on the blue line and red line, but looking it up I discovered there is a whole different loft  in two places  "solid" and "Surface" - Who would have thought.   Thanks again your demonstration was a great help.
Tom Combs
