Create circular pattern greyed out
tmarr8
tmarr8
I've created a fan blade and would like to create a circular pattern to duplicate the blade.  However, the circular pattern button is greyed out no matter what I try.  And ideas?
TrippyLighting
Please provide at least a screenshot including the browser tree and menus. You could also make a screencast.
mike.tessier
Hi there!
I see you are having some trouble producing a circular pattern. I  would just like to ensure that you are selecting the correct dropdown menu, as there is a circular pattern command for sketch entities and a completely separate circular pattern command for patterning features, bodies, components, and faces.
Attached are screenshots of the locations of the two different commands. Hope this helps!
Create Drop Down
Sketch Dropdown
Cheers,
Mike Tessier
Product Support Specialist
My Screencasts | Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
tmarr8
Thank you Mike.  I was using the wrong pattern selection.  Duh.  Still learning.  Love the application so far.
