Create a y=a*x^2 parabolic line in Fusion using the conic curve tool?
josikWFKBV
josikWFKBV
Hi all,
I am trying to create (draw in a  sketch) a simple parabola that follows the equation y=a*x^2, where the a is a defined parameter that the user can change. I was looking into the conic curve tool and it seems like such can be accomplished but I am not too sure how.
Does anyone have any ideas how I can create such a parabola without having to use external scripts?
Best,
Jo
johnsonshiue
Hi! At the moment, Fusion does not have a native workflow to generate an equation-driven curve. Here are a few ways to do that using scripts. Please take a look.
https://forums.autodesk.com/t5/fusion-educators-read-only/quot-equation-driven-curve-quot-app-for-fu...
https://capolight.wordpress.com/2018/07/02/how-to-sketch-equation-curves-in-fusion-360/
Many thanks!
Software Test Engineer
josikWFKBV
@johnsonshiue thank you very much for your reply.
I do understand that Fusion does not have the native workflow for equations. But I thought that there is a way how to tailor a conic curve with a rho value of 0.5, which from my understanding makes the curve a parabola for a y= a * x^2
jeffescott
Yeah maybe.  So you say 1/.5 = an exponent of 2.
Then if you would fit the end points
of (0,0) and (1,1).  You could calculate a.
and there you go a work around.   Ill try that.
