create a tooth form around an extruded body
Hi all
I'm currently working on a project and wanting to create a toothed form around an extruded body.
is there a quicker way to do this rather than using the sheet metal function then bending the strip with the tooth form already on.
please see example below.
regards Aaron
g-andresen
Please share the file.
File > export > save as f3d on local device  > attach it to the next post.
günther
Please see files needed attached
Regards Aaron
g-andresen
At the moment.I can't think of a better way than this.
günther
Thankyou for your solution much appreciated.
I will have a play around with the unfold function, seems a quicker way then doing each bend individually.
Regards Aaron
