Create a thin air filter
igelbriefkasten
igelbriefkasten
Hello everyone.
I have modelled and air ventilation system and would like to include a thin layer representing an air filter. It has to be see-through, so I am wondering what a good approach would look like (keeping in mind that the filter will need to be 2000 x 300 mm, so I guess extruding a pattern with millions of holes is not a good idea, as well as pattern a feature this often will blow the program in my experience)?
It would be fine if it is a texture or similar applied to an appearance, no need for it to look perfect, I just need to represent the effect when looking through it and I want to show the part in an explosion drawing.
If anything is unclear, please let me know.
Looking forward to modelling,
Daniel
TrippyLighting
If this is for visual appearance, then a texture, with a similar setup to the perforated leather textures in Fusion is the right way to go.
The most important section is the Cutout section,  which will provide the see-through areas for the holes.
The Aluminum Mesh with small hoes texture might already be good enough for your purposes.
igelbriefkasten
Thank you - completely forgot about the perforated textures. They absolutely do the job, look great and I can even create different coloured versions.
Fantastically simple solution in this case.
jhackney1972
It is customary when someone gives you a solution that satisfies your needs and answers your question to mark their post with the "Accept Solution" icon.  @TrippyLighting  gave you a solution that your acknowledged worked for you so please select the "Accept Solution" on his post.
John Hackney, Retired
