create a simple tire..
t_lamourine
Message 1 of 12
t_lamourine
very new to fusion 360 and want to create a simple tire, but needs specific sizes/dimensions.
Have attempted a few things but something about this program screws with my normal "order of operations" thought pattern.
My general idea would be to draw a profile on either Y or X planes then just circle extrude around a Z center..   just can't seem to get it.. any one have a basic idea/tutorial on steps to go about it...
should be simple,.. yet.. just not wrapping my brain around it.
Replies (11)
Message 2 of 12
fritter63
I created a screencast for you on how to do it, but it doesn't seem to be uploading or processing. That seems to be broken for me after the last update (even after updating screencast app too).
So in case it doesn't upload, here are the steps:
1) create a sketch on a plane
2) in the sketch, create the profile (cross section) of the tire. Make sure it is a closed profile, i.e., the no open sides, and can be highlighted as such.
3) close the sketch, under "create" menu, choose "revolve"
4) after closing the profile from the sketch, select the "axis" button and then the 3 axis/planes will show up. Select the one perpendicular to your profile, and then you can select
the options, but you'll just want the default of 360.
5) then your tire will be created.
Message 3 of 12
t_lamourine
thanks.. kinda what I was thinking but for some reason I can't get it.. thiunk I'm just looking for diff names to tools/actions is all .. I'll try again later with your steps.. thanks again !! 🙂
Message 4 of 12
fritter63
OK, I figured out my screen cast problem. Apparently if you pause an upload, it log jams all later uploads too!
Here is the screen cast:
https://knowledge.autodesk.com/community/screencast/20fc4a8d-668b-40ed-8541-a9d83be1d899
Message 5 of 12
TrippyLighting
This thread is the first thing that comes up when looking for tire using the Forum search function :
https://forums.autodesk.com/t5/design-validate-document/draw-tire-tread-on-round-surface/m-p/6353818...
Message 6 of 12
t_lamourine
ya, saw that but i's about adding the texture/tread to the tire.. not actually creating the tire in the fist place.
Message 7 of 12
t_lamourine
that's cool.. kinda the idea I had originally.. clears up a bit for me.. but getting specific dimensions in to parts I'm finding rather difficult, and it looks easy in all the demo's but after I draw it's not letting me change/input stuff.  😕
REALLY like the screen recorder!!!  is that a F-360 thing or some outside app you are using?
Message 8 of 12
fritter63
It's part of F360. It's a separate app, but you have a button in F360.
For dimensions, you can use "sketch dimension" to constrain lines, diameters, etc. Pay attention to the other sketch constraints that can be subtle and frustrating when you
aren't aware of them.
Then use "modify parameters" to make the values "variables" and then you can use the variables in the sketch dimensions.
Ie, add a parameter named "TireRadius", then create a construction line the dimension it as "TireRadius", then create your cross section at the end of that line.
Later, if you a bigger tire, just change that TireRadius value.
Message 9 of 12
t_lamourine
ahhh think this is the step/thing I'm missing!!!!!  i was trying to use the "measure" tool
Message 10 of 12
fritter63
@t_lamourine
Here's another screencast showing you how to parameterize. I screwed up on some of the naming and it didn't quite "react" as I expected, but you can get the general idea from this.
Note that I had to restart F360 after my first try because it had lost the ability to mirror in a sketch (this happens to me occasionally, and on other features, so keep in mind it might not be you when it won't work correctly). yeah, welcome to the world of F360... it ain't perfect, but it is **** good.....
https://knowledge.autodesk.com/community/screencast/dedf6b18-55f9-4206-ab2f-f49cad00c82a
Message 11 of 12
t_lamourine
awesome... I like that idea of basically building a skeleton !
Message 12 of 12
TheCADWhisperer
Click the Next Step button 4 times after opening the attached to see step-by-step creation technique (without tread).
