Create a Groove
Create a Groove
alan
Create a Groove
alan
To create a groove in the outside of a cylinder (radial groove) I have been drawing a profile and revolving the sketch.  There has to be a way to add a groove to cylinder after the cylinder is created.  Please  help.
One way would be to create a sketch of the grove shape and revolve that around as a cut to the original cylinder.
Looks like once you do that it will then allow you to press/pull the new groove cylinder as well as both circular faces created to resize the groove to what ever you want.  Though I would probably go back and edit the sketch instead.
O.Tan
Care to give a quick print screen so we know and can give suggestions on what you want to achieve?
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
