Create a driven dimension manually
juliangall
juliangall
If I fully constrain a sketch and then add a dimension, it becomes a driven dimension. I can then remove a constraint, but the driven dimension is still there and still driven.
Is there any way to add a driven dimension manually to a sketch that is not fully constrained? i.e. To arrive at the same point as above.
Julian
TheCADWhisperer
Right Click
juliangall
Thank you. I see that when I do this, it no longer shows a parameter name when I hover the mouse over it. I guess this means I can't reference it in other dimensions if it's driven. Why would that be?
TheCADWhisperer
@juliangall wrote:
...Why would that be?
Because apparently the Fusion team does not communicate with their Autodesk Inventor teammates "across the hall".
patrick_gouraudb3hd9ufd
Community Visitor
Community Visitor
How do you make a driven chamfer then ?
jhackney1972
Create a Parameter that will drive the Chamfer size.  The Chamfer will use the parameter as a Driven dimension.
John Hackney, Retired
TheCADWhisperer
@patrick_gouraudb3hd9ufd
This is a 7-year-old discussion thread.
Fusion has changed to allow driven dimensions in parameters.
Can you File>Export your *.f3d file to your local drive and then Attach it here to a Reply if you can't figure it out?
