create 3d path with constant elevation
Message 1 of 8
I'm designing something like a rollercoaster for steel balls. I draw an spline, then elevate each point to desired height, but I prefeer not to do it "at sight", I want to know if there are any way to select start_Z and end_Z for an spline with several points and take a constant degree downhill.
Replies (7)
Message 2 of 8
etfrench
  1. On sketch one draw a line at the desired elevation angle.
  2. Create a Plane at Angle using the above line as input.
  3. Create a sketch on the plane.
  4. Draw the spline on the plane.
ETFrench
Message 3 of 8
Thanks for your reply, but it doesn't work: if the payh is U shape, for example, start point and end point should be at same level. Path isn't in a plane, path also could pass below itself.
Message 4 of 8
TrippyLighting
In that case you might simply need more than one plane and maybe a few construction planes to serve as axis for construction planes.
Message 5 of 8
etfrench
Here is a convoluted way of generating planes with a constant elevation.  Perhaps you can find a way to use it.
ETFrench
Message 6 of 8
davebYYPCU
As long as the horizontal spline continues to radiate from the centre, you can do a reasonable job with a conical ramp, and project to surface for the Path.
Message 7 of 8
thanks, I'll check those solutions
