Crash while trying to select sketch profiles through bodies.
This has happen to me multiple times,
Fusion crashes while trying to select multiple sketch profiles through a body. I extrude a body from the sketch, make the sketch visible again and press the Q key,  change selection filters to select through and select sketch profiles only, select the first profile I want and the selection filters reset,  reset the select filters to through and sketch profiles only and try to select the second profile, Fusion crashes.
paul.clauss
Hi @Anonymous
Thanks for posting! It is unfortunate that you are experiencing this crash when selecting sketch profiles through bodies. We apologize that you have been experiencing this issue.
I had a look at your crash reports, and it looks like you are actually crashing due to a known issue in which Fusion 360 crashes when the Select All selection filter is disabled during an active command. This problem has been logged with our development team as FUS-16642 - I have made a note linking this forum thread to the report and will keep you updated as I have more information to share about a resolution.
In the meantime, changing the selection filters before entering the press/pull dialogue should allow you to avoid this issue. You could also try holding down the left mouse button to bring down the drop down list as an alternative method or selecting sketch profiles through bodies.
Please let me know if you have any questions - I'm happy to help!
Paul Clauss
Product Support Specialist
Thank you,
I will use the work around until a solution is found. Thanks for the outstanding customer service I have received since I down loaded the program.
Thank you,
