Could someone collaborate with me to do the spring part of hand grip
I am completely new to Fusion 360, it's been just a week so I am trying to design a hand grip which is used in exercise, but I am not able to build the spring part of it I tried so much but I am just a beginner who cannot find out the solution
So I need to make the spring part of this, it would be great help if someone would like to collaborate with me, I know this is not a great project to collaborate, but i could learn so much by joining with someone.
LeonardoBN
Hi @sachinnath492.
You could use the Coil tool for this.
I recorded a simple Screencast.
Note that the spring will be in a different axis from the hand grip's own axis. As you already have the handles, you can use joints to assemble everything.
Leonardo Brunelli do Nascimento
Chemical Engineer
Great, thank you so much for this I didn't know how to do it, can we create the spring in a different file and then assemble the handle as well as the spring in a new file or should I make the spring in the same file itself and use the rigid tool join them.
LeonardoBN
...can we create the spring in a different file and then assemble the handle as well as the spring in a new file or should I make the spring in the same file itslef and use the rigid tool join them.
What will you do with this model? Are you going  to use these parts repeatedly?
If not, you could hold spring and handles in the same file, but in different components.
Chemical Engineer
Thank you for your help, I completed it 😄
