Correcting dimensions
Message 1 of 9
On Mac, Newbie question:  After I've created an object, like a cylinder, I later want to change the dimensions.  How can I do this?  I cannot seem to find a method to bring up a modifiable bar that shows the current dimensions.
Thanks for your patience!
Replies (8)
Message 2 of 9
Hi @Anonymous
welcome to the Fusion community.
If you created a simple cylinder feature see attached video how to edit from the timeline:
Josef
Message 3 of 9
josef.kucera
Sorry, I used my Adsk testing account for the answer.
This is my right account.
Josef
Josef Kucera
Fusion QA
Message 4 of 9
Hi Josef,
  Thanks.  So, when I created the cylinder, I did not get a pop up menu on the right side of the screen, as happened in your video.  What sorts of information did you input there, and why might I not have seen such a popup?
-Rick
Message 5 of 9
Hi Josef,
-Rick
Message 6 of 9
Hi Again,
    I also do not have anything that resembles the timeline in the video. There is a small timeline down in the lower left of the screen, with scrolling arrows and one icon for the Cylinder Primitive object created, but I can't seem to get to a more complex timeline like the one in the video.
    -Rick
Message 7 of 9
Hi Josef,
   Okay, I finally managed to access the modification system by double clicking on the icon of the object in the timeline.  That problem is solved I think.  As to how I can bring up the more complex timeline representation, I'll keep trying the shotgun method.
   Thanks for your help!
-Rick
Message 8 of 9
josef.kucera
I'm sorry for the trimmed video where isn't obvious what I clicked in the context menu, I recorded a new where it's more obvious...
Double-click on objects in the timeline works as well for edit.
There's an issue that sometimes you have to select object first (left-click) in the timeline and then right click to get the proper context menu with the Edit command.
Josef
Josef Kucera
Fusion QA
Message 9 of 9
Josef,
   Thanks again for your help.  So, one of my problems is that with this new computer I'm using a bluetooth mouse that for some reason the right click was not enabled.  Just did that, and now I can bring up the menus in the timeline.
XOX
   -Rick
