copy, paste, duplicate Text
I am working on a flat panel and need to add text for laser engraving.  Working in Sketch mode I can add  a text block and set the parameters for the text needed (Arial Rounded MT Bold, Text Height 0.200 inch).  This is a simple process.  The next time I add a text box, all the parameters return to default, I have to set everything again.  In addition, if I use the "rectangular pattern" duplicate command on the text boxes all that duplicates is the box, no text or settings.  Since I am placing the same text multiple times on my panel I would like to use the "rectangular pattern" tool instead of placing new boxes for each and every line of text.
Questions:
1.  How/where do I set the "default" setting for new text boxes?
2. Is there a way to Copy/Paste or duplicate text boxes when working in Sketch?
HughesTooling
Copy and Paste work on text in a sketch, it looks like pattern doesn't though as you've found. One thought, can you make your extrude then use pattern from the create menu to copy the 3d feature.
Mark
Mark Hughes
Owner, Hughes Tooling
mike.tessier
Hi @Anonymous,
Thanks for posting!
@HughesTooling is correct, copy/paste should work on the text in the sketch.
Unfortunately, it doesn't look like there is a place where you can set the default settings for text boxes. Upon investigation, I wasn't able to find a post in the Fusion 360 IdeaStation.
Maybe this would be something you would want to put up there?
Hope this helps!
Mike Tessier
Product Support Specialist
My Screencasts | Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
