Copy and move an extrusion
Hi folks,
I'm trying to create two new extrusions on the far right of this body, which are rotated at 90 degrees to the other extrusions (marked with the red lines). I used the mirror tool to create the existing four by constructing a new plane.
I'm at a loss about how to create these last two extrusions. There should be a way to copy the holes and move the copies to the desired location.
Extrusion.JPGThanks!
HughesTooling
As the pockets need rotating as well it's going to be easier to make another sketch and extrude. Actually edit the sketch you used for the first pocket and add one of the slots that go the other way. Extrude cut and mirror or pattern for the other. Probably should have just drawn the 3 pockets across the bottom of the part then patterned to create the other 3 in the first place.
Mark
Mark Hughes
Owner, Hughes Tooling
lichtzeichenanlage
You're making things to complicated. Simply sketch it.
chrisplyler
I think I would just do this:
