Copy a component (with paste new) and redefine a sketch plane on the copy
I have to say I have grown very frustrated and from reading what I can find in the forums, I'm not alone.
I have a component (body + 5 sketches). I want to make an unlinked copy of that component, move it to a new location (capture position), and then redefine the sketch plane on one of the sketches for the new component to a different face on that component.
Everything I try, it would appear the component is not truly an independent component. After I have the component copied and moved, I select 'redefine sketch plane' on the new component's sketch, the component visually jumps back to the original position (overlaid on top of the source component). Even so, I select the new face, and the sketch does not move to the new face. and the extrusions based upon that sketch disappear.
When I delete the copied component, it prompts with 'this component is referenced by other stuff are you sure?'. How can it be referenced by anything else when I just made a fresh 'paste new' copy?
What am I doing wrong?
--eo
