Converting Fusion file to .dae (Collada) or .scn on a Mac
lskaling
lskaling
Greetings! I'm experimenting with apple's AR Kit, which requires using either .scn or .dae (Collada) format to display a 3d object. I've been looking around and I the only two options I found were to use the Collada Writer plugin, which is only available for windows, or someone said using Autodesk Maya. I imported my cad to Maya, but when I export, it freezes until I need to force quit it. Any other suggestions, or does someone know how I can prevent Maya from freezing? Thanks!
SaeedHamza
I'm sorry but this is the Fusion 360 Forums
You can ask this in Maya Forums here : https://forums.autodesk.com/t5/maya-forum/bd-p/area-b201
Regards
Saeed Hamza
