Hello Guys and Gals,
I have a project I'm working on that involves CT scan data. I use a program called Osirix to generate a 3D surface model from CT scans. The data can be exported into .iv, .obj, .stl, .rib, and .vrml. I have been able to import the .obj and .stl files. I am able to see the surface model, but I can't seem to do any operations on the surface.
I'd like to be able to convert the surface to a solid and then cut and modify as if it were a regular part file. I have read some of deyo's comments that converting a surface of trangles to T-splines is not an easy task. I was hoping someone could help me with this conversion. I am using a Mac, but I have access to a PC if there were some free conversion software. I've added a sceenshot so you can see what I'm working on.
Thanks!
Roger
